My old Square D pump control switch was making multiple arcs when switching off, and I could not find any obvious faults (pump prssure on/off spring setting, 1/4" pressure check tubing, bladder tank air ressure, etc). So, I came a conclusion that the switch is bad (1.5 yr old). The new one I got (Centri Pro) is missing one feature - manual to control the pump off/on/auto lever on the side.
This is my Goulds J10S jet pump.
This is the OLD Square D switch with the lever on the side.
This my NEW Centri Pro switch w/o the lever.
I've used that lever on the old Squre D switch whenever the pump would not turn on automatically. W/O the lever on the new switch, is there anyway to manually turn on the pump?
