Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > Just a bad water pressure gauge?
Old 01-22-2014, 02:31 PM   #1
kudzu
Default Just a bad water pressure gauge?
Hi, Water pressure gauge reads zero but pump seems to run alright. No obvious loss of pressure as pump does not kick on more than usual. Can pressure gauges go bad with no harm to the system? Will get it replaced but did not want to make an emergency drive to Home Depot in snow.
kudzu is offline
Old 01-22-2014, 02:59 PM   #2
Chris
Administrator
Liked 497 Times on 439 Posts
Likes Given: 42
Sounds like a bad gauge to me, if everything is still working fine I'm sure you can wait til after the storm to get a replacement.
Chris is offline
Old 01-22-2014, 03:27 PM   #3
kudzu
Thank you for the reply
kudzu is offline
Old 01-23-2014, 01:40 PM   #4
speedbump
Liked 47 Times on 46 Posts
Likes Given: 13
Keep in mind, the gauge has nothing to do with your water system. It's just for setting a pressure switch which was set up during the original installation.
speedbump is offline
Watts Pressure regulator does not hold water pressure GoshenPlumber General Plumbing Help 2 05-05-2013 12:27 PM
T-ing Two Water Supply Lines for Greater Water Pressure JZeld General Plumbing Help 15 03-12-2012 08:13 AM
water pressure sky rockets when water heater is on jfrisby General Plumbing Help 2 02-16-2012 02:45 PM
Meter Gauge for Private Well ku2 Pumps and Wells 5 10-08-2011 01:42 PM
Cold water pressure lower than hot water Va_guy General Plumbing Help 3 07-11-2011 12:50 AM
