Plumbing Forum - Professional & DIY Plumbing Forum > Specific Plumbing Discussion > Pumps and Wells > Issue w/ well pump, pressure tank or pressure switch???
Old 10-26-2012, 07:25 PM   #1
Default Issue w/ well pump, pressure tank or pressure switch???
Here is what is going on with this persons well setup:
When water is in use from a faucet, the water flows correctly for the first 2 to 3 seconds, then the flow of water drastically slows down to almost nothing, then it picks back up within a few seconds again, and continues to flow at a resonable flow rate. Any ideas?
I am thinking its the pressure switch, I dont believe it has anything to do with the pressure tank failing, as that usually makes the pump contiously run.
Thanks for your help.
pmoney1983 is offline
Old 10-27-2012, 02:48 AM   #2
Water well,and septic guy
waterwelldude's Avatar
Liked 2 Times on 2 Posts
It sounds like the tank may be waterlogged. If its a bladder tank check the air in the tank.
It should be 2 to 3 psi less that the pressure switch cut on pressure. if its not a bladder tank, drain the tank dry, that will
give it a fresh start. Also check the line going to the pressure switch as sometimes they get clogged with minerals and need to be cleaned out.
If all that checks out, watch the pressure switch. If the pressure drops way down before the pump kicks in
it may be time for a new switch.
Edit Signature
waterwelldude is offline
Old 10-27-2012, 01:48 PM   #3
Liked 24 Times on 24 Posts
Likes Given: 11
Actually it makes most pumps cycle on and off rapidly. Submersible pumps especially.
speedbump is offline
Will Increasing Pressure Tank Size, Increase Pressure? Keith Pumps and Wells 8 07-13-2012 05:18 AM
Pressure switch/well pump issue? ah55 Pumps and Wells 6 02-25-2012 11:03 PM
Pressure Switch or Pump problem? ericivins Pumps and Wells 7 01-17-2012 08:41 PM
Piston pump & pressure tank? beerman Pumps and Wells 11 09-28-2011 01:39 PM
Pump/pressure tank detective needed ngermain Pumps and Wells 1 05-05-2011 03:59 PM
