How to turn on sprinkler pump? (novice=may be an easy answer!)
Hi All,
I'm a new homeowner with an underground sprinkler system, that also has a pump (due to low pressure of city water). Although I've opened up sprinkler systems in other homes before that don't have a sprinkler pump, I do consider myself a novice. Currently, water does flow through the sprinkler heads, but with low pressure, while noticing the pump not turning on.
I noticed the pump is connected to a relay box, which is also connected to the sprinkler control box. The control box and the relay are both plugged into a working outlet, but the pump does not turn on....making me think there is a simple switch to turn it on, that I'm not finding? If so, would anyone know where I can find that switch?
The pump is: Myers model # RJ50S (The sprinkler control is Rain Dial RD900-INT).
Would anyone know how to turn on the Myers RJ50S pump, or where the pump's on/off switch is?
Thanks,
cg
