As John said, probably a cross connection with the hot and cold. You could also look into a few other causes of the cross. If you have a hot water recirculation line and the pump is failing/failed and there is no backflow or check vale on the line. It also happens when a hose is connected to a laundry tub that has the hot and cold valves open, but the hose nozzle is closed. The water will cross the valve body and the hot will enter the cold piping.
Just do a little poking around anywhere you have a hot/cold faucet and try to remember if anything was changed or added around the same time that you noticed the problem. Post back and let us know.
