Old 01-12-2012, 06:36 PM   #1
Default Grinder pump question
Hi,
I'm hopeful that someone can help me. I'm building a new house upstate, we're doing everything (apart from the foundations) ourselves. We were informed that we would need to install a grinder pump in the house, which would run to the main sewer line.
There is only one toilet in the house, so we didn't think it would be an extreme expense, was i wrong!
After looking at grinder pumps, we figured a smaller one would suffice. Yet, now we are being told that we have to have one that is minimum 220v and 1 1/2" output. The quotes i have gotten are around the $4,500 mark, and that's even without installation.
Surely there has to be something under a thousand that we can install?
We don't have a basement, so it would have to be installed outside, i had planned to build housing under the crawl space and install it there, right under the bathroom.
The distance from the grinder pump location to the main sewer lines is approx 40 feet.
please help!
newhouseconstruction is offline   Reply With Quote
Old 01-12-2012, 10:12 PM   #2
unfortuneatelly that is the going price for grinder pumps in that range. even with only 1 toilet there are things that go down into the lift station that arnt easilly ground up and 220 volt is the minimum you would need so as not to be constantlly poping breakers.
what is happening is that your homes services exit the building under the grade level of the nearest sewers and so a lift station must be installed that is capablle of keeping up with the demand with all fixtures running and that is based on the disvcharge pipe size, which I wager having done the math before that 1 1/2 is what the installer has figured would be able to keep up. otherwise what ends up happening is that the holding tank overfills and starts to back up into the main DWV piping, and finally starts comin out of the lower fixtures such as showers and tubs on bottom floor.
This is a case of "Do it right the first time or regret it later and spend even more to have it fixed and done right"
Shop around and you may find better pricing but 5 Grand is a common starting Number for installation and material, we did one of these a few weeks back and the final bill was around that mark.
You are definatelly not going to find anything that will suit your needs for under a grand, Sorry.
Hope this helps.
Old 01-13-2012, 01:16 AM   #3
Yea and plan on installing it in a location that is very easy to access as you will need to maintenance that thing periodically. if you dont plan on doing it then you will have to pay someone to and the harder it is to work on the more expensive it will be.
Draindit is offline   Reply With Quote
Old 01-13-2012, 01:30 AM   #4
I have zero knowledge on this topic, but I Googled "macerator" and found numerous pumps, as well as toilets with built in macerators, and the most expensive one found was $719, and that included the toilet! I also looked around for any 220v units, but was unsuccessful.
Old 01-13-2012, 02:31 AM   #5
Water well,and septic guy
waterwelldude's Avatar
There are other pumps out there that are around 600 to 1000 dollar range that will do what you are asking. Do a search for sump pumps that can handle 2" solids and has a two inch discharge. They are not built as good as some of the more expensive grinder pumps, but should last you more than a few years. Something along these lines may give you some time to build up some money to get a better pump in the future.
(Grinder pumps) by name are for the most part very expensive, but they are built to do as there name implies, and they do last for a number of years.
Edit Signature
Old 01-13-2012, 06:38 PM   #6
As waterwelldude said there are many pump systems that will work that won't break the bank. Check out Zoellers packages.
910 Sewage Systems | Zoeller Pump Company
Old 01-14-2012, 12:16 AM   #7
Definitely follow john's lead and links on this one. I have installed these same systems and they have a great performance record. Some that I have serviced have run 8-15 years without issues (depending on what was put down the drains).
A $4,500 quote on a new construction install...actually, without installation, seems very high. Could there be some details that would warrant such a high cost that weren't mentioned?
Old 01-25-2012, 05:07 PM   #8
Hi,
Not leaving anything out. I've had a quote for the pump package only and it's been the cheapest one i can find so far, it's for $3,500 for Liberty 2484LSG outdoor package... Anyone have any suggestions to something that would be the same, only it wouldn't leave me eating ramen noodles for the next year? that doesn't include installtion, just the unit.
the only problem is, it is a mandatory 1 1/2" discharge. So i can't use anything that is 2", I've asked why and just told, that's it.. want plumbing, you get that a unit that conforms.
Old 02-02-2012, 07:53 PM   #9
I personally love me a Myers grinder pump. I know first hand that they can grind up snakes (yes, the REAL reptile, not a cable rod!) so they go thru solids with ease and the motors last a long time. Last one i pulled out was a Myers and it was 16 years old.
Matt30 is offline   Reply With Quote
Old 02-02-2012, 11:58 PM   #10
Yup myers are awesome, this is what we replace outdated grinder pumps with in my area.
