Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > Fitting a shower pump
Old 08-22-2012, 09:28 AM   #1
connett
Default Fitting a shower pump
Hi guys, i am wanting to fit a shower pump ans my existing shower pressure is rubbish i have a gravity fed system ( water tank in loft cylinder in a cupboard in the bedroom) i want to fit the shower pump in the loft if its possible i read there beeds to be 600mm between the bottom of the tank and the top of the pump is this correct? is there any measurements etc. that i need to check? And is is as simple as cutting the pipes and connecting the pump?
Thanks, Mark
connett is offline
Old 08-22-2012, 12:26 PM   #2
Liked 392 Times on 328 Posts
Likes Given: 556
From similar questions asked in the past, I am thinking that you are in the UK, correct?
I have never installed such a system before. Normally, when we here stateside have a pressure problem, a booster pump is added to the whole house, instead of just to a single fixture. But perhaps one of our pump guys can chime in with a helpful answer.
Old 08-22-2012, 01:09 PM   #3
speedbump
Liked 47 Times on 46 Posts
Likes Given: 13
I'm not real sure what you have. If you can explain it better along with the type of pipe and it's size, it would help to understand your problem. Is the pump your referring to just going to be used for the shower?
speedbump is offline
Old 08-22-2012, 01:23 PM   #4
connett
Hi mate i have 2 15mm feeds H & C running to the shower the hot feeds from the cylinder up to the loft then to the shower and the cold feeds frrom the header tank to the shower. It will purly be used for the shower as the rest of the system is mains fed.
connett is offline
Old 08-22-2012, 01:23 PM   #5
connett
They are copper pipes
connett is offline
Old 08-22-2012, 02:05 PM   #6
speedbump
Likes Given: 13
That's roughly 1/2". Can you use a 12 volt pump instead of an AC electric variety?
Old 08-22-2012, 02:11 PM   #7
connett
Possibly but both feeds need to be equal pressure wont they?
connett is offline
Old 08-22-2012, 05:47 PM   #8
speedbump
Likes Given: 13
I don't know, I don't know anything about how you have it plumbed. I was just suggesting a little 12 volt pump that has a built in pressure switch. When you turn on a faucet, it starts and makes pressure. Where it would go in your plumbing would be up to you to figure out. Unless you can get us some kind of diagram of your plumbing.
Old 08-22-2012, 06:40 PM   #9
connett
Ok well this is bacically it minus the pump and U at the side of the cylinder
I cannot lift the tank high enough to clear 600mm only around 400mm available
connett is offline
Old 08-22-2012, 06:56 PM   #10
speedbump
Likes Given: 13
Can any of you Plumbers make anything out of this? I don't know what I'm looking at. I understand check valve and stop valve and that's about it beside the shower.
what is a transition fitting? Another-Plumber Water Heaters and Softeners 22 12-20-2012 10:36 PM
Y Fitting with Valve? menkes Plumbing Products 4 02-04-2012 03:28 PM
Tub to shower fitting Jhawker General Plumbing Help 1 11-04-2011 11:11 AM
Swivel fitting joe42 General Plumbing Help 1 10-13-2011 10:36 PM
Compression fitting barquito General Plumbing Help 5 01-21-2011 06:34 PM
