Plumbing Forum - Professional & DIY Plumbing Forum > Specific Plumbing Discussion > Pumps and Wells > Combination sump pumps
Old 02-04-2013, 09:20 PM   #1
Likes Given: 2
Default Combination sump pumps
Hello,I need advice concerning the best combination sump pump system for a home.The pit is 18"x28" and the original Hydromatic sump pump failed,and I want to insure that does not happen again.I want to put in a combo unit 2 pumps and a battery backup.I have read all over net last couple of days,what Ive seen is the BW4000 system by Glentronics.Another brand is Wayne.Anyone who knows about this I would appreciate hearing from.Thank you for your advise!
Rmany31 is offline
Old 02-07-2013, 02:25 AM   #2
Liked 66 Times on 56 Posts
Likes Given: 53
If you install two pumps and a battery backup run two discharge lines, one for single pump & one for pump and battery backup. make sure you install check valves in the proper place.
Old 02-13-2013, 09:00 PM   #3
Likes Given: 2
Hello,I bought a Zoeller 507-0008 which is the m53 primary and the 12v backup all switchs plumbed from the primary up past backup.The primary has a hole in connector beneath primary check valve and a vent hole on pump itself.They say another vent hole 3/16" or larger is recommended but not actually required.I have seen videos on youtube for installation,they dont mention at all drilling a second vent hole.Should I drill another above backup pump and install another check valve there, it would also be under pit cover.Thank you!
Rmany31 is offline
Old 02-14-2013, 02:01 AM   #4
Likes Given: 53
see your other post
Re-Circ pumps? bhamiltonjr General Plumbing Help 9 05-25-2012 02:27 AM
Piping for sump pumps Russell General Plumbing Help 3 03-23-2012 06:39 AM
water-powered sump pumps zoefungal General Plumbing Help 2 10-15-2011 10:24 AM
HP of Booster Pumps elmer Pumps and Wells 1 08-14-2011 03:31 PM
Sump pumps Septik Pumps and Wells 4 07-06-2011 05:28 PM
