Originally Posted by waterwelldude
Check the air pressure in the tank in a week, if the air pressure you put in there has dropped more than 2 or 3 psi, its time for a new tank.
First, thanks for your response.
That's a very good idea - checking it in a week.
But a leaky schrader valve could be a cause for the pressure drop, couldn't it be? I don't know how often such a bad schrader valve is found on bladder tanks, but I wonder if there is way to replace only the faulty valve and save the tank.
Right now this is what's happening.
> Pump cuts out (OFF) at 50 psi.
> Pump cuts in (ON) at 45 psi.
I only have a 5 psi range.
I am thinking the bladder tank air pressure is too high, right?
And what is that black tube connecting to the switch?
