Plumbing Forum - Professional & DIY Plumbing Forum > General Plumbing Discussion > Pumps and Wells > Black Water
Old 08-15-2011, 09:52 AM   #1
Beeston
Default Black Water
Hello, this is my first post and i am seeking help for a water problem at my house. The water entering my system (from a well) is crystal clear. When it hits my pressure tank/sprinkler system is has a black tint to it and kind of smells of metal. PLEASE HELP! I will give any further information if needed.
Beeston is offline
Old 08-15-2011, 10:51 PM   #2
LiQuId
Liked 15 Times on 11 Posts
Likes Given: 20
sounds like you have a ruptured diapragm in a pressure tank.... replace the pressure tank.
well experts here will give you other ideas if mine is bunk... though I am pretty sure this is your problem.
LiQuId is offline
Old 08-16-2011, 01:46 PM   #3
speedbump
Liked 47 Times on 46 Posts
Likes Given: 13
Yup, could be the tank. What kind of tank is it? If it's a bladder tank, what brand? If it's a galvanized tank, do you know if it has a float inside? Do you have a chlorinator?
speedbump is offline
Old 08-16-2011, 03:05 PM   #4
Driller1
Driller1's Avatar
I was wondering how you know it is clear going into the tank.
Driller1 is offline
Old 08-18-2011, 09:01 AM   #5
Beeston
Bladder, The brand is a flotec. I know it is clear because it splits of into to separate systems. One for our main house and one for a rental. The rental's water is perfectly fine. We do not have a chlorinator but currently thinking of getting one. Could Anaerobic bacteria be the problem?
Beeston is offline
Old 08-18-2011, 02:07 PM   #6
speedbump
Likes Given: 13
The tank is bad. All you had to do is say Flotec. They typically last about 1.5 years. When the bag tears, the water gets into an unpainted metal tank that will start rusting rapidly and will mess up your water.
It can also shorten the life of your pump when it gets waterlogged.
Black polybutylene? phishfood General Plumbing Help 2 01-29-2012 12:04 PM
Black particles in water tazfan Pumps and Wells 21 12-31-2011 07:08 AM
Black specks in urinal dp815 Toilets and Sinks 2 01-15-2011 02:29 AM
Black Plastic Flakes Coming From Cold Water woodebbie General Plumbing Help 1 12-07-2010 11:25 PM
RV black water overflow wp630 Drain and Sewer Cleaning 5 03-10-2010 06:43 AM
